TwinTurbo.NET: Nissan 300ZX forum - a vac line from the egr valve runs to the egr solenoid
ali300zx
on October 10, 2009 at 8:54 PM
Where do the vac lines run on the EGR?
posted by d_flore
on October 10, 2009 at 02:21 PM
near the battery
Is the EGR valve stem supposed to leak??
Zarcasm(Hfd, CT)
23:59:48 10/09/09
Check the EGR with vacuum since that is the signal that >>>
ZUL8TR
07:53:47 10/10/09
Actuating vacuum is not the problem
Zarcasm(Hfd, CT)
14:42:56 10/10/09
I agree if the plenum is leaking air that would effect>>>
ZUL8TR
19:27:04 10/10/09
Vacuum reading at idle is OK with EGR leaking but...
Zarcasm(Hfd, CT)
00:16:02 10/11/09
That old link for vacuum test was a deja vu for me...
ZUL8TR
08:01:48 10/11/09
I'm not buying Leaky Valve Guides yet...
Zarcasm(Hfd, CT)
09:25:51 10/11/09
OK let's hope not..................>>>>>>>>>>>>>>>.
ZUL8TR
06:28:56 10/12/09
Timing problems are a possibility but...
Zarcasm(Hfd, CT)
15:20:15 10/12/09
Speaking of fuel pressure.
canyoncarver
08:35:34 10/13/09
Internal fuel leak? Good question!
Zarcasm(Hfd, CT)
19:36:34 10/13/09
Zarcasm(Hfd, CT)
21:20:07 10/13/09
Valve Cover Oil Cap Diagnostic Test is Inconclusive
Zarcasm(Hfd, CT)
15:40:14 10/12/09
Wow! this is getting like an Agatha Cristy Mystery>>>
ZUL8TR
08:12:48 10/13/09
Yeah. EGR operation checks good but valve cover vacuum???
Zarcasm(Hfd, CT)
19:31:07 10/13/09
Still strange that you do not get a reduced vacuum >>>
ZUL8TR
07:24:19 10/14/09
If you don't, it could help quite a bit if you had
canyoncarver
08:51:04 10/14/09
Tell me about it!
Zarcasm(Hfd, CT)
20:34:03 10/14/09
PS have you checked the coolant thermostat>>
ZUL8TR
08:22:42 10/13/09
Coolant Temp Sensor is good
Zarcasm(Hfd, CT)
19:03:08 10/13/09
d_flore
14:21:31 10/10/09
a vac line from the egr valve runs to the egr solenoid -
ali300zx
20:54:38 10/10/09
IMHO, your EGR valve should not leak at 1 psi.
canyoncarver
19:57:51 10/12/09
I'm still not sure there's an air leak worth worrying about
Zarcasm(Hfd, CT)
22:24:11 10/12/09
